what is a 383?
Old 10-02-2004, 10:47 PM
RUINED's Avatar
Default what is a 383?
can someone tell me is a 383 a stroked 5.7? is a 408 a stroked 6.0? what about a 5.3? also can someone explain to me the lt1, lq4, lq9, ect.....what is my 02 5.3? isn't a T something? i want to learn this. thanks
Old 10-02-2004, 10:59 PM
Formerly one92rs
one03sierra's Avatar
Talking
383=stroked 5.7-yes
408=stroked 6.0-yes.
5.3l = 325 cubic inches.=lm7 i beleive.
lq4=6.0l=9-1 compression. 2500 and 3500 engine and in some bigger trucks. the lq9 is a 6.0l also. but it has 10-1 compression. it is gm's high output 6.0=ss's.-vho's and escalade ext's.
Old 10-02-2004, 11:01 PM
chevymec's Avatar
A 383 is a 350 with a 400 crank.. The 408... not too sure.
LT1 was in the 4th gen camaro and C4 corvette
LQ4 is the standard 6.0 like the HD trucks carry
LQ9 is the 6.0 in the SS and VHO models
LM7 is the 5.3 the T if im right is the letter in the vin for the 5.3
Anybody else wanna through some in.
Old 10-03-2004, 02:45 AM
dkubricht's Avatar
is there a stroked 5.3?
Old 10-03-2004, 02:51 AM
Baltimore Whore
Mangled03gmc's Avatar
a 383 is a 350 wit a 400 sb crank
Old 10-04-2004, 09:45 AM
86SWB's Avatar
383 is a 350 bored .030" with a 400 crank.
Old 10-04-2004, 01:02 PM
bigbody's Avatar
Dont they use the crank out of the 327s to make some kind of other stroker
Old 10-04-2004, 02:01 PM
Baltimore Whore
yeah they use the 27 crank in the 350.it is something lik 330ish ci.high rev motor
Old 10-04-2004, 02:18 PM
04BlackSilverado's Avatar
Some other Combinations of these can yield the same results, like give up some bore but replace it with stroke.
A 402 is a 6.0L LS1 block with 4.000" bore x 4.000" stroke
A 370 is a 6.0L LS1 block with 4.030" bore x 3.622" stroke
A 409 is a 6.0L LS1 block with 4.030" bore x 4.000" stroke
A 414 is a 6.0L LS1 block with 4.060" bore x 4.000" stroke
A 422 is a 6.0L LS1 block with 4.030" bore x 4.125" stroke
Does this help or confuse you?
Old 10-04-2004, 02:20 PM
14 Second Truck Club
onyx's Avatar
dont forget the 94-96 impala SS.
Quick Reply: what is a 383?
