whats the biggest tire i can fit on my 95' suburban?
Old 06-28-2007 | 09:25 PM
Default whats the biggest tire i can fit on my 95' suburban?
hey guys,
im from over at the LS1tech site and i need some help with my dailydriver,
right now i have the stock size tires, but now i want to put the biggest ones i can fit, anyone know what that is? btw i have 15" rims
Old 06-28-2007 | 11:18 PM
Tootall's Avatar
2wd or 4wd? All terrain tires , or streets?
31x10.50x15 will clear, and full lock will be ok Speed O will be 2-3 mph slow
32x11.50x15 will clear, but the will rub at full lock. Speed O will be 3-4 mph slow
Old 06-29-2007 | 11:32 AM
its a 2wd, and i want some tires in between offroad and street, like the M/T baja tires, i really just want a tire that looks mean, but has good street manners
would a 32x10.50x15 be the best looking and best fit?
and i have a welder, to get the 32x11.5x15 to fit could i easily just notch the frame alittle in the front where its needed?
Old 06-29-2007 | 12:03 PM
Tootall's Avatar
the 32's will fit, but they'll rub on the front bumper, top of fender, and rear bottom fender.
The front bumper can be cut/notched with a saw-zaw
the top bang it in with a hammer, or do small cuts with a hack saw, and "roll" the inner lip of the fender up.
the back side of the front quarter pannel can be cut, and also rolled back
Lots of this depends on what wheels you have and back spacing you have. I had 33x12.50x15s on 15x10s. This was a with a 3" body lift. The rubbed in all the places that I described above. They never hit the frame, even when air borne.
Old 06-29-2007 | 01:49 PM
i have the stock rims. im just trying to get the biggest tire to make my car a little cooler, because all my time and money usally goes into the camaro
so if i get a 31x10.5x15, all should be ok and it will fit with minor things?
Old 06-29-2007 | 06:38 PM
Tootall's Avatar
31's will fit with absoulty no issues at all . . . . slap them on and drive
I had the BFG long trails/ or open trails, and I've loved them. They're a great highway tire
Old 07-05-2007 | 01:18 PM
TigerEyz3's Avatar
Assuming your referencing a 2wd OBS, you should have no problems fitting 32x11.50x15 on a 15x8 wheel - no trimming and no on-road rubbing (I get a little frame rub at full lock).
Also, in response to the speedo calibration... 3-4 mph is not totally accurate. Go with percentages. For example, going from factory (29") to a 32" tire, you're going ~10% faster than your speedometer reads - when your speedo reads 60mph, you're actually going 66mph; at 30mph, you're actually going 33mph.
If you've got factory 15x7 wheels, I'm not sure how well the 32x11.50 will mount - may be a bit too ballooned, but may not. May want to go with the 31x10.50x15 instead.
I like how the 32" fills the fenderwells, but I think they are a little too tall for optimal road handling - I like to hang curves more than I like to off-road. Shorter tires = less body roll / tire flex. Always something to factor in when considering SUV handling.
Zizzle
10-19-2017 08:44 PM
Corvette454l88
09-01-2016 01:24 AM
caliSSclone
07-23-2015 11:04 PM
mrgrim
07-08-2015 08:12 AM
Quick Reply: whats the biggest tire i can fit on my 95' suburban?
