Where's the coolant leak in my 5.3?
I hate to make my first post a thread asking for help, but maybe you guys wont mind.
I've got a 2000 Sierra and over hte last year or so I keep getting the "Low Coolant" light on the dash after running for a while. At first it would happen once a month or so, at most. It's gotten more and more frequent to where it happens almost every time I drive it, but always after a few minutes of driving.
I never noticed my coolant being very low, combined with the fact that my temps hover right around 195-200 (Im assuming the 'stat is set around there?) and it never gets hotter than that regardless of how many times that light comes on, so I just assumed it was some sort of silly sensor going crazy.
Well I went to change the oil in it the other day and I found some antifreeze leaking down the back of the oil pan. At least it's not a slowly failing headgasket or something, so I actually felt a little better about actually finding a leak. Unfortunately, I couldn't get a good look at where it was coming from, and I haven't been able to figure it out. I just cant get a good look at the back of the motor. Do you guys know of any typical leaks that manifest around that area? I was thinking maybe an intake manifold leak or something. But maybe a leaky heatercore somehow manages to leak back there also? Im not really sure. Im doubting a freezeplug rusted through... and other than that I'm at a loss.
That sounds like a pretty good lead. How expensive is this tube? It's way too cold for me to go out there poking around on it right now, does the whole intake need to be replaced (you mentioned welds...) or what? Hopefully after I go look at it agian things will become clearer, though.
9 Second Club
coolant leak
this must be a popular prob. mine is leakin from the driver side waterpump gasket. i had to remove the plastic brush gaurd to find it and even when i did that it was still a bi*#h to see it.
Whatever it is, it's a very, very, very slow leak, and that one time on the back of the oilpan is the ONLY time I've ever seen it. I've looked since and seen nothing.
I dont know, maybe it is travelling all the way around? Stranger things have happened... I'll give it a look.
Yeah exactly. I would have thought the same thing if it had been leakng at the front.
