Wide band Vs Narrow band
Old 12-06-2011 | 05:53 PM
Slammed96's Avatar
Default Wide band Vs Narrow band
I'm curious as to what exactly the advantages are of running a wide band afr setup as opposed to a narrow band. The only thing I can think is the ability to data log with the wide band, but aside from that, what are the main advantages?
Old 12-06-2011 | 06:19 PM
Atomic's Avatar
I have a gauge for that
the stock 02s are narrowband and only accurate at lambda=1
widebands are accurate over a range like lambda=0.7 to 1.2
Old 12-06-2011 | 08:25 PM
Slammed96's Avatar
So pretty much you just get a wider, and probably more accurate, range of measure.
Old 12-06-2011 | 08:27 PM
smokeshow's Avatar
Mod with training wheels
Accurate in the sense that a wideband can actually get a correct reading... Precision is lower with a wideband, but it is a wider range. Narrowband O2s are very precise.
Old 12-06-2011 | 08:59 PM
Atomic's Avatar
Think of narrowbands like a switch; they are either on or off. In the case of the narrowbands on your truck they read high or low, very accurately, at only 1 point. Now with a wideband think of it like a gauge, you are now able to see quantitatively how far away from lambda=1 (Stoich,ie, where your narrowbands are useful) you are. This is a very big deal since if you are for instance running a turbo you want close to 11:1 afr. If you only have a narrowband, it would show the same reading for 14:1 as it would for 9:1, so you really have no idea what the actually amount is other than you know its "rich".
Old 12-06-2011 | 09:43 PM
Slammed96's Avatar
Gotcha. That actually makes far more sense than I thought it would. Thanks guys!
Old 12-06-2011 | 10:00 PM
DTHPROOF's Avatar
Awesome explanation Atomic!
Old 12-06-2011 | 10:07 PM
bruiser04's Avatar
all i know is when i see 11's and 12's im havin fun but when i saw 17s on the old motor i was pretty bummed lol
thompson
12-27-2017 07:48 AM
BROKE-aSS-BLAZER
10-13-2017 04:50 PM
Gadgetized
10-22-2015 10:06 AM
03sierraslt
14
10-09-2015 06:53 AM
blown02408
10-01-2015 02:06 AM
