Wierd "clunk" noise/voltage drop
I have a 99 GMC Z71 ex cab. Everytime I shift in drive/reverseand press the throttle, there is a "thump/bumb/clunk" noise, just one, coming from under the floorboard. As soon as the noise happens, my volt meter drops instantly. This process happens in the blink of an eye. It is right under my feet where the shift cable runs.
The noise will not occur if I do not press the throttle. I can shift in gear and move by idling and it will not happen.
I went to check the alternator and battery. Everything is perfect. The mechanic said "it could be a solenoid"
This problem is pissing me off. Any suggestions????
Originally Posted by NoChrome
Thats what I was thinking... kinda weird.
Hey Josh got the decal on, Bad ***. Your the man!
how long do you wait from switiching from r to d cause if the trans doesnt not build up pressure again to apply the correct gear it will surge line pressure when reving hesitate cause of the clutch slippage and then go also going to jolt the drivetrain prolly causeing a clunk
