Will these rims fit and if so what tire....
I'm sure some of you truck guys have experience with older models so i hope you can help me. My brother has a 95 S10 Blazer 4X4 that came from the factory with 15x7 rims with 235/75/15 tires. I recently put new rims and tires on my 2001 Z28 so I have the 16x8 from my car just sitting around. Since his rims are all scuffed up from years of use would it be possible to put my 16x8 rims on his Blazer? And if this is possible what size 16 inch tires should i go with? The Blazer is mainly highway driven and only see's 4 wheel drive use in the winter snow. Thanks
Location: as far away from Koonerville as humanly possible
Re: Will these rims fit and if so what tire....
I know they work on the 2wd's, but not 100% sure if they will work on a 4x4 (offset may be different?).
This site says you can get away with a 30x9.50x15 on a stock height Blazer, which is about equivalent to 245/75/16.
You can use this site to play around with different tire sizes.
http://www.miata.net/garage/tirecalc.html
FlowmasterMufflers
11-24-2015 01:00 PM
LSX-81-SIERRA
09-05-2015 02:51 PM
