WOW This is going to haul a$$
that thing has a nice list of stuff for the motor and such::
Finishing up an installation that has been on-going for about a year.
Should be complete in another month.
The Truck is a 2000 S10 Blazer, 4 door with Autotrac 4WD.
It came with the Trailblazer option.
Motor is a new 6 Liter engine with the following components assembled by Keith Craft Motors:
-Comp Cam XR265HR-15
-Big pushrods and beehive springs
-ARP fastners and Head bolts
-Mild ported LQ9 Heads.
-Diamond forged pistons - 9 to 1 CR
-Modified Canton LS1 oil pan for front differential clearance
-Powermaster LS1 starter
-Optima Battery
-Corvette engine accessories and brackets - powder coated
-Aluminum radiator w/dual puller fans
-Ed Wright Dynotune
-Shorty Stainless headers - Heat coated
-Dual Random Technology converters
-Magnaflow 3" muffler dual in-single out
-Magnuson Supercharger 7-8lbs boost
-Vette 90 MM TB Drive-by-wire
-Z06 MAF
-4L65E Transmission with Shift kit and Vette Servo
-2000 Stall Converter
-3.73 Gears front and rear
-Aluminum driveshafts
-TA Diff Cover
-Posi in rear axle housing
-HD Transfer Case
-KB Boost-a-pump
-255 lph Walbro pump-hotwired
-Edlebrock Performer shocks
-AGR Quick ratio Steering Gearbox
-SSB13" triple piston front brakes
-Hydroboost Brake system
-18x8 Konig Wheels
-255/55 Pirelli Scorpion Tires
-Custom Hood lift strut kit
-JL Stealthbox sub
-JL 5/1 Amp
-JL front component speakers
-Factory head unit
-Optima Battery
-Ed Wright Dynotune
-Z06 MAF
-TA Diff Cover
-HD Transfer Case
-KB Boost-a-pump
-18x8 Konig Wheels
-JL Stealthbox sub
-JL 5/1 Amp
-Factory head unit
Skip Fix
22
07-09-2016 07:08 PM
hirdlej
08-27-2015 10:22 PM
