WRX owner told me he's running 50 psi of boost
hah some tool told me his GN( which was 'oddly' nowhere to be seen )was running 45 lbs of boost and that it ran get this....12.0's i then asked if he wanted to race sometime and he then said the car had recently burned to the ground after he rolled it over at the track......
Originally Posted by TurboBerserker
You see what you can do if you use the green boost fluid instead of the orange?
Tribe Shaman
the only supercharger i know of that will make 50 lbs of boost is the one's for the funnycars and the rails, it has a 7 to 8 inches more to the length then a 871 B&M. i know the blades in that puppy has got to be at least 16 to 18 inches long. and it is made only for a big block.
Sometimes those ricers calculate boost by taking atmospheric pressure at ~30 #/sq. in. and then add the 20 # of boost to get 50 # total. (which is the way it's done in an aircraft)
Originally Posted by Paperchaser
this kid i know had a TT geo prizm. he had the orange stuff in so long that it turned green. once that happened, he could get another 5psi out of it. i had a video of the car but you can see it very well. i couldn't move the camara as fast as the car was going
