Your thoughts on going from 255/70 tires to 265/75's?
My truck is a 2wd and I've lowered the rear 2" to level it out. I'm thinking about going to a bigger tire for 2 reasons, 1) to fill in the wheel wells more since I won't be lowering my truck any more and 2) to help me get some traction. I have 255/70's now and am thinking about getting 265/75's, the 255's are 30.1" tall and the 265's are 31.6" tall. That's 1.5" difference and will effectivly change may 3.73 gears to 3.55's because of the taller tire. I have a real bad time now with traction, tires spin real easy. I'm thinking this change will help traction but I also don't want to loose all my low end. Should I do this or stay with the same tire height and just get real good tires?
Jim
Jim
Re: Your thoughts on going from 255/70 tires to 265/75's?
The factory generals SUCK! My rears were bald at 8000 miles with 3.42 gears. Find some better tires.
<small>[ May 07, 2002, 12:00 PM: Message edited by: white53gmc ]</small>
i suggest some bfg radial t/a 275/65/16. they look pretty bad *** and give pretty good traction. i have the hothkis 2/4 drop so it kinda fills the well a little more but i have some before/after pictures. check out the sig. and click on texas members, i'll have the only truck on there, also if you click on my picture it'll show more pictures.
<small>[ May 07, 2002, 02:25 PM: Message edited by: Phatchevy ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">i suggest some bfg radial t/a 275/65/16. they look pretty bad *** and give pretty good traction. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sounds like just what I looking for. I check the size of the 275/65's, they are the same height of the 255/70's plus they are a fatter tire, more tread on the ground.
Jim
Jim
11 Second Truck Club
Y2K- Are your 255's Generals or some other brand? Just wondering-cause I've been meaning to make a post to see if anybody else has been as impressed with the Generals as I am. I hook comletely on just about any surface-a lot of times when I am trying to show off instead of peeling out it just goes. I have about 11,000 miles and the back ones are about gone but I have been attributing this to the fact that they must be a soft comound and soft compound=quick wear but good traction. I was planning on going to a 18inch wheel and using the 295/45/18 Goodyear F1 like the lightnings use but I have already bought some more Generals and have them sitting on the shelf ready to go.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Y2K- Are your 255's Generals or some other brand? Just wondering-cause I've been meaning to make a post to see if anybody else has been as impressed with the Generals as I am. I hook comletely on just about any surface-a lot of times when I am trying to show off instead of peeling out it just goes. I have about 11,000 miles and the back ones are about gone but I have been attributing this to the fact that they must be a soft comound and soft compound=quick wear but good traction. I was planning on going to a 18inch wheel and using the 295/45/18 Goodyear F1 like the lightnings use but I have already bought some more Generals and have them sitting on the shelf ready to go.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My stock Generals wore out in 20K, these tires are Pep Boy Adventurer HT'S. I got them because I read a write in Truckin mag about a year ago about them. They had some one from the Hotkchis Company test them for them and give his opinion on them as a replacement for an OEM tire. They drove a Suburban with the stock tires (Uniroals I think) around a road course and through a slalom. Then they put on these tires and re-tested, the Burb ran quicker in both tests and the tester gave them a thumbs up for a good replacement tire for someone who want to spend a lot of money on tires. I think they've sucked from the day they were installed, pulling out of the parking lot after they were installed I spun the tires which it wouldn't do with the General tires. It spun them at every stop on the way home with out me trying, I just thought it was because they were new and had a film of crap or something on them. They've gotten better and I have increased the power in my truck but they still suck. I would put a set of the stock Generals on in minute before I would do these tires again.
Jim
Jim
