Zero compression #4
#21
I'm glad that it was something simple and you were able to just get away with basically freshening them up. I completely understand having to work on something like this in might near 100deg heat, it's just plain miserable, but at least once you get done you can set back and sip a glass of iced tea and enjoy the fact that you didn't have to spend too much getting her back going.
#22
Got the heads back with new springs, seals, and valve job. The new springs tested 10 pounds higher than the old ones. Now its time to go to work in 99 degree heat. Head shop said the 060 heads were the first in a long time that came in not cracked.I bought new head bolts too.
#23
Thanks for your help on the forum, while doing the head job I replaced the spider with the 8 injector type. The injectors don't fit real tight in the holes of the intake, and wondered if I should put a little silicon around the top of the injectors in the hole.
Thanks, Gary
Thanks, Gary
zblee
11-11-2015 12:41 AM
