2/3 drop how do I do it? 2012 Silverado 1500 4X4
Old 09-27-2012, 03:21 AM
JCunningham's Avatar
Default 2/3 drop how do I do it? 2012 Silverado 1500 4X4
I did a search and although there is 3 pages none of them really answer much.
I know nothing about lowering my truck but what iv read on here. Whats the best way to do this? Looks like I will need Ground Force front spindles. 2" rear shackles and remove blocks. Will I need shocks? Will anything handling wise be changed? I want a OEM quality ride or better and a OEM quality kit. Will I have any Vibration? Will a rear Sway bar still fit? This is a daily driven truck that will see salt and winter and be used as a truck. A truck with a SC 6.2L but a truck. I saw this truck and this is exactly what I want.
Old 09-27-2012, 06:05 AM
Allgonoshow's Avatar
that's my 08 4x4.
It has 2 in ground force spindles, 2 in shackles and blocks removed.
It sits with a slight front to rear rake, higher in the rear.
The wheels are Black Rhino's and tires are Michelin at2 285/55/20.
No need to change shocks and it is an easy install at a good front end shop.
You will need the alignment checked after.
If you change spindles and not springs or struts you retain your factory ride.
I have done the same suspension change to 3 nnbs trucks and have had no driveshaft vibration in any of them.
My 2010 has the same suspension and GM 20's with 285/20/20 toyo's
Old 09-27-2012, 01:00 PM
cool thanks. I can do every think my self so this should only be around $500 for the drop.
Old 09-27-2012, 01:37 PM
AUTOT3K's Avatar
Cut the first groove off your rear bump stops. Check my "bumpstops" thread for pics. I'll be updating it this evening with measurements and the 3" rear drop pics
Old 09-27-2012, 01:46 PM
sounds about right, don't forget the alignment
and what he said on the bump stops
Old 09-27-2012, 08:23 PM
AUTOT3K's Avatar
just to reinforce what I said earlier.
heres where you'll be sitting at 3" drop without cutting bump stops
and here's where you'll be sitting cutting off the 1st groove, rides like factory again. dont make my mistake haha, do it this way the first time!!
Old 09-27-2012, 08:31 PM
rcsb jon's Avatar
stylintrucks.com has the belltech #25003 drop struts for $190/shipped, which offer 2" of drop.
the benefits of this are:
-easier install than the spindles, plus no risk to damaging ball joints
-no decrease in turning radius, which the spindle will do
-performance shock valving
shackles, with the bolt spacers to pull the rear blocks, can be had fr $80 shipped from summit
So you should have only $270 invested in parts and like $70 for an alignment
Old 09-27-2012, 11:39 PM
the install is no problem for me I can take this truck apart and put it back together. So even the Ground Force spindles will reduce my turning radius? how bad. I want to do Bilstien shocks and structs
Old 09-28-2012, 06:47 AM
ground force doesn't reduce turning radius at 2 inch drop and 285 tires.
my truck goes full lock both sides and doesn't rub
Old 09-28-2012, 08:25 AM
rcsb jon's Avatar
Any and all spindles will reduce turning radius... its based on design, not rubbing
Mcgaughys does make coil relocators... theyre like 125. but then the bilsteins will be like 400.
I say do the belltech all around. The rears are like 120/pair.
so 191+118+67=377 total for your drop with the shackles/block removed and will handle great. its a proven setup
Quick Reply: 2/3 drop how do I do it? 2012 Silverado 1500 4X4
