Dod delete part list
this is a list to do a DOD delete on a 5.3, the same thing would go for the 6.0 and 6.2 but you would need L92 head gaskets *ONLY IF IT HAS DOD ALSO* but you'd have to purchase the front cover.
LS2 timing cover sensor gasket and seal 12633906 (only needed if you have VVT)
Cam Gears *there are 2 options*
Single bolt *you already have this cam gear if you have a 4.8/5.3*
3 bolt
Part Number: 12586481
Head Gaskets
Part Number: 12498544 *this is for 2 5.3 head gaskets, not the single pack*
LS7 Lifters
Part Number: 12499225
LS2 Dampener *i recommend to swap this because the factory tension is JUNK*
Part Number: 12588670
Lifter Guide *you need 4 of these*
Part Number: 12595365
Valley Cover *without AFM and without the PVC vent (known as the 4.8 valley cover. it is just like the LS3/7 valley cover just half the price)*
Part Number: 12598832
LS9 head gasket: 12622033 *you need 2*
L92/LS3 (6.2) head gasket: 12610046 *you need 2*
6.0 head gasket: 12589227 *you need 2*
info added from AUTOT3K
non VVT front cover: 12633906 (only needed if you have VVT)
Various Gaskets
Water Pump X 2 12630223
Valve Cover X 2 12637683
Oil Pump O-Ring 12584922 - orange
ARP Head Bolts for 05+ block 134-3610
ARP LS crank bolt (except LS7) 234-2503
ARP cam retainer plate bolts 134-1002
ARP cam sprocket bolts 134-1003
Your total for the cam/dod delete with parts will range about 1600-1700 depending where you can save on costs
3 bolt
Head Gaskets
LS7 Lifters
Various Gaskets
