07-08 4L60e to 6L80e swap
Old 11-30-2010, 05:45 PM
  #101
iamkeniff's Avatar
that crane pays the bills very nicely i made 2.75hrs of O.T today sitting on my butt day dreaming about finishing this lol
Old 12-01-2010, 07:58 AM
  #102
mnm8977's Avatar
Niff, this is a great post. I have a 2008 Silverado CC I have been wanting to do this swap for a while now. Currently I have 5.3 AFM 4L60E. when I'm done it'll be a 6.2L stoked to 427ci. with a 6L90E. Just wanted to say thanks for all the leg work you've done. Great looking truck by the way. Have you found out anything in reguards to the PRNDM display and Trans Temp on the DIC?
Old 12-01-2010, 08:31 AM
  #103
iamkeniff's Avatar
as far as the DIC/gauge cluster no. i havent even tinkered with it yet. i have a feeling the BCM will have to be flashed with a newer truck. the problem with it really, is the 09+ gauge clusters are different than ours. Skipperdaddys electric part of his gauge cluster isnt like mine at all. my mirror has the direction/temp his gauge cluster has that in his. the rest is the same. he has blue tooth and digital a/c gauges, i dont. id have to find a truck that doesnt have any of that stuff and flash it into my bcm i think. ill do more digging later on after the truck is up and running. the truck using our shifter/gauge cluster when you put it into D like normal it will run through all the gears, it wont select the gear for you. i have a feeling if i swap to my manual shifter it wont do anything either. its all in the computer of the tcm thats probably controled by the BCM kinda like the Tow/Haul button will be through the BCM.
im going to get with John @ speartech for more info on it.
Old 12-01-2010, 06:27 PM
  #104
iamkeniff's Avatar
driveshaft is dropped off, and should be ready next week. then its time to start tuning it. i cant wait to get this thing done.
ALSO the shifter bracket is CRAP i could have made that thing at work BUT for 5.00 i cant complain lol
Old 12-01-2010, 09:37 PM
  #105
skipperdaddy's Avatar
Peel out!!!!!!!!!!!!!!
Old 12-02-2010, 05:36 AM
  #106
iamkeniff's Avatar
the CC cant peel out but the WT can nikka....
well i have to take the back half of my driveshaft to the shop too so it'll either be today if i get off early or tomorrow if they tell me take off. but more than likely Monday
Old 12-02-2010, 08:11 PM
  #107
iamkeniff's Avatar
gonna throw a beginner tune in the truck Saturday but cant crank it until i get the driveshaft back.
Old 12-03-2010, 08:32 PM
  #108
iamkeniff's Avatar
if you are going to run the stock 4spd shifter cable you have to modifiy the new bracket by 1/2" or it wont bolt in. pretty simple fix.
Old 12-03-2010, 09:22 PM
  #109
keep the good info comin man.. good write up!
Old 12-03-2010, 10:00 PM
  #110
iamkeniff's Avatar
eh ill probably just update after im finished theres really nothing else to buy or swap except my driveshaft stuff
Quick Reply: 07-08 4L60e to 6L80e swap
