07-08 4L60e to 6L80e swap
Old 12-04-2010, 03:51 AM
  #111
GMCSIERRA5.3's Avatar
nice thread
Old 12-04-2010, 01:38 PM
  #112
iamkeniff's Avatar
we have a basic tune and the truck spins over just fine the only thing is it wont allow the tow/haul button to work so ill probably have to get the BCM flashed.
Old 12-04-2010, 04:28 PM
  #113
iamkeniff's Avatar
pretty simple install. pull the 10mm bolt for the park brake release. pull the 2 screws. pull the whole bottom cover off. pull the 2 covers apart around the steering wheel. pull the rubber boot to the end of the shifter, remove the torx screw. remove the 4 10mm nuts that hold the lower bracket under the steering. then remove the 4 15mm nuts and drop the steering down. remove the 3 torx screws holding the "selector bracket" then install the new one that only has the P R N D M. reinstall in reverse. FYI it will not have tow/haul or the manual shifter options until you flash the BCM with the new server. *this is just a theory, may not be the problem*
Tools needed:
15mm deep drive 3/8" drive
short 3/8" ratchet
6" extension
10mm 1/4" drive deep drive
6" 1/4" extension
short 1/4" drive ratchet
Old 12-04-2010, 05:41 PM
  #114
mhotrodscooter's Avatar
Could I do this in my truck?? Lots of good info here. I hope you can get what you want out of the swap.. BULLY
Old 12-04-2010, 05:44 PM
  #115
Tools needed:
short 3/8" ratchet
6" extension
6" 1/4" extension
Could I use a air ratchet here?
Old 12-04-2010, 06:22 PM
  #116
pewterliftedz's Avatar
lookin good niff. Ur gettin to the part that I want to know. If we can use alll the goodies like the manual
Old 12-04-2010, 06:29 PM
  #117
iamkeniff's Avatar
yeah if u want but i feel sorry for you if you break stuff
Old 12-05-2010, 12:19 AM
  #118
14 Second Truck Club
double047's Avatar
wow niff i go away a couple days and you got this thread really looking good, very nice job on the detail man, this is sure to be a sticky sooner or later
Old 12-05-2010, 12:56 AM
  #119
Foxxer's Avatar
This thread makes me wanna swap in a 6l80e already.
Old 12-05-2010, 12:59 AM
  #120
FrankyRST's Avatar
damn someones been busy, keep up the good work
Quick Reply: 07-08 4L60e to 6L80e swap
