07-08 4L60e to 6L80e swap
#322
The plugs for 2 and 4wd transmission is the same it will just have the transfer case connectors on it, i am fairly certain the speedo reads off the transmission oss....
Niff awesome write up man, have you done anything more with the tu/td? I am seriosuly thinking about swapping a 6l80 into my yukon....
#323
Nah sure haven't been pretty lazy considering i don't drive it very often.
It's spent so much time sitting the battery crapped. Replaced it, then when i decided to drive it, boom dead battery.
I just have my tow/haul set up to control it to downshift for roll racing
#326
Will do, im going bit different as a have a harness off of a used engine i installed last week that had a couple of the wire bundles cut so i am going to pull the trans connector and probably vvt and repin my harness, if my harness isnt already set up for vvt, have seen a few non vvt trucks that have already had the wires for the vvt in place just seem to need the actuator harness on the timing cover....
#328
I have an awd 6l80 from a 10k mile 2010 Denali. Comes complete with the transfer case, front driveshaft, and cooler lines. No converter. Let me know if you're still hunting for one and if this suits your needs
