07-08 Airaid Jr Kit works on 09+
Import Moderator
Not sure if anybody else has posted this up or not but if you are looking for an intake for you 09+ and you don't feel like spending $350.. the Airaid Jr kit will work perfectly. There was also a thread recently about a K&N tube fitting as well so I believe the necks are still on the same angle/length. So go ahead and get rid of those restricting stock tubes if you haven't already ![Wavey](https://www.performancetrucks.net/forums/images/smilies2/wavey.gif)
![](http://i225.photobucket.com/albums/dd188/beastmode02/100_2365.jpg)
![](http://i225.photobucket.com/albums/dd188/beastmode02/100_2364.jpg)
![](http://i225.photobucket.com/albums/dd188/beastmode02/100_2363.jpg)
![](http://i225.photobucket.com/albums/dd188/beastmode02/100_2362.jpg)
Notice any difference with replacing the stock tube? Im on the verge of buying this just curious if you think its worth it. Im sure with a re-tune it would be even better but just wanted to know what you thought.
Import Moderator
Good ****. I figured most were buying up the Volants but that kit cost to damn much for me.. I paid $147 for the Airaid tube and replacement panel filter shipped to my door
Actually I have yet to drive it... I installed it tonight and didn't take the truck out. I know the stock tube is so restrictive but I can't see the gains being very noticeable. For $150 tho I figure even if I save a little on gas its well worth it
and some pics of a 07-08 K&N tube on a 09+. Personally it looks like the fitting on the neck of the box looks a little off on the K&N but he said it still works so
sweet i wanted to do this for my 2010 hows the crank breather hose working out figured this might be the one set back for a homemade setup with some tubing and fittings, does it work well with the 08 jr kit
