07-13 Silverado/Sierra Transmission Spacer
FormerVendor
We finally added the Belltech Transmission Spacer to our site.
This spacer is good for the 2WD models of the 07-13 Silverado/Sierra.
Belltech Transmission Spacer for 07-13 Silverado/Sierra
What is this spacer for?im new to the lowering stuff. I have a2010 silvarado 2x4 im wantin to lower 2inches also. Whats a good kit? Im wanting 2 front and back. Im wanting a better ride quality
FormerVendor
If you want a simple 2" front drop and 2" rear drop, I would suggest using Belltech's Lowering Struts for 2" and 2" rear shackles. Here are some links.
Struts on SALE $75 each
Belltech Lowering Strut 07-13 Silverado/Yukon/Sierra/Tahoe B25003
Shackles
The Suspension Source 88-13 Chevrolet Silverado/Sierra 1/2 Ton (All), 88-10 Silverado/Sierra 2500/3500 (All), 92-99 Tahoe, Yukon & Suburban (4dr. Only) 94-01 Dodge Ram 1500 (All) 97-03 Ford F150 (All) 2" Rear Drop Lowering Kit
FormerVendor
You can go as low as 5/7 if you have some horsepower behind the truck. 2/4 is more of a level appearance than the 2/2. Personally I like the 3/5 drops on these trucks. Allows for a bigger tire to be used.
