07 GMC Denali Another TPMS Question
Hi gang, long time no see. I have been searching through threads trying to make sense of a TPMS issue. My 07 Denali decided it was going to start through TPMS errors in the console and it will not read both rear sensors. I tried to do a relearn, and only my initial driver side tire, will sound the horn when detected. When I try to relearn the other tires, it will not respond to them at all. I have new TPMS' in the tires, and they still are not responding. Is there anything else I can replace? Obviously the sensors are new but, how do I troubleshoot the receiver ?
Thanks
Thanks
Thanks
Thanks
I bought an Autel TS408 to program the sensors on my 06 Suburban. I think it may have some function to test signals?
Depending on where you got the sensors I've had more than one bad one right out of the bag even from GM.
The simplest solution for your headache is go take it to a tire shop discount tire etc pay them to replace all 4 and program em. Then when and if they fail in the future you don't have to eat dismount re mount and balance
The receiver for the TPMS is the keyless entry module receiver and since 2005 I've never had one go bad and not read sensors or some but not others so it's not your problem.
Go drive it a bit and see if the computer will pick them up. My after market wheels on my 24 give the sensor programmers a fit, have to set the computer to look for them and go drive it every time.
69blueSS
08-04-2009 04:31 PM
