07 Silverado ABS and Brake light... Help
Old 11-23-2009 | 07:16 PM
Relentless07Silv's Avatar
Exclamation 07 Silverado ABS and Brake light... Help
Well I had my gears changed to 4.10's and after I had them done I started throwing ABS and BRAKE lights. The truck is tuned by wheatley and tuned RIGHT for the gear ratio and the tire size. He was puzzled with this also and even sent the tune to hp tuners and they coulden't find a problem with the file. He cant pull the codes either cause i don't have a check engine light cause the problem is in the BCM.I took the truck by the dealership just to see if they could hook it up and tell me if it was a sensor but that was a waste of time and i was told i would pay 90 bux for them to say its my tire size... Does anyone have any clue what can be done? Any and all info would help.
Old 11-23-2009 | 07:42 PM
Beyond Static's Avatar
Did you try unhooking the battery and letting the truck sit for an hour or so? Also, try zip tie'ing the ABS connector plugs together incase it has a loose connection. Did this to my '09 and it solved my abs and stabilitrack lights
Old 11-23-2009 | 07:49 PM
tallChevy's Avatar
is your truck lifted
Old 11-23-2009 | 07:53 PM
Battery has been done, and i can try the zip ties but we will see. The truck is dropped not lifted but has been throwing codes before the drop. Appreciat the help keep em coming
Old 11-23-2009 | 09:12 PM
RedHot04's Avatar
try cleaning the vss on the tranny. that was a prob for me before. or the sensors on the wheels. easy things to try before you spend $$...
Old 11-23-2009 | 11:10 PM
Daryn's Avatar
Formerly darynC-10/23/10
dont worry. it will go away after a few weeks. mine did the same thing
Old 11-24-2009 | 10:47 AM
Its been doing it for a good couple months now i think its gonna stay till whatever it is is fixed.. Its really annoyying too it it beeps 23 timesss trust me i knowwwww lol
Old 11-24-2009 | 05:31 PM
Had a similar problem
https://www.performancetrucks.net/fo...ight=wallywall
According to the tech that fixed mine, BCM and Speed sensor had to be recalibrated along with the computer.
Old 11-24-2009 | 06:45 PM
lady3bglover's Avatar
I know I'm not running the same truck, but I had a similar situation.. all I had to do is change the solenoids in the ECBM. I found some on line from a place in Dallas for $100.
SLOPONY
20
10-18-2016 06:05 AM
5.3Caprice
11-07-2015 08:56 PM
Offroadunleashed
07-20-2015 02:25 PM
1320Chicken
07-14-2015 10:58 PM
mrgrim
07-08-2015 08:12 AM
Quick Reply: 07 Silverado ABS and Brake light... Help
