09 Sierra 6.2 1 3/4 vs 1 7/8 Headers
Old 01-03-2014 | 12:42 AM
A converter is your next best performance supporting mod and will give a noticeable driveability difference. Then you are prepared when the cam and blower or spray time comes and it will.
1 7/8 may gain you some at the high end of WOT but really it's a truck how often does full WOT every last pony performance come into play in a DD scenario unless you are racing the truck.
Old 01-03-2014 | 03:15 AM
Spencer1990's Avatar
Whats the best converter for my truck also will I gain anything with no cats and how much louder would it be with my mods. Thanks
Old 01-03-2014 | 04:22 AM
rijrunr's Avatar
Chris at Circle D build mine based on what I do with my truck. I opted for the triple disk, because I am throwing nitrous at it and plan to beat on it.
Old 01-03-2014 | 06:06 AM
skeet's Avatar
whats your peak torque? once you know this you'll know what converter to get
get the headers then cam then stall to match after dyno!
Old 01-05-2014 | 06:53 AM
iamkeniff's Avatar
skeet knows his stuff
i cant give exact advice on the 1 3/4 vs 1 7/8 bc i dont have track numbers to back it up due to changing combos an not being tuned yet.
mine traps 105.5 to 107.9 with the 1 3/4" ill know how it does jan 30th though on the dyno
Old 06-21-2014 | 04:54 AM
Longbow's Avatar
Seeing as how you are not FI, I doubt you would notice a gain from the header swap. I definitely think the larger primaries would be a mistake, as your exhaust port is significantly smaller than 1 7/8". Any time air flows into a significantly larger opening, it loses velocity. The other members seem to have the right idea about focusing on other mods. Good luck!
Edit: Post is way older than I thought lol!
Old 06-26-2014 | 07:30 PM
Blackpanther99's Avatar
Converter!
Old 06-26-2014 | 08:58 PM
ZR1 DREAMING's Avatar
Although I say converter first, then cam, you have to keep in mind the cam you have spec'd will rely on your exhaust as well. You need to decide if you're staying at 1 3/4 or eventually going up to 1 7/8", that will determine what your cam should be ground at.
What is your end goal and purpose? You may find the 1 3/4" will suffice long term for you and you can put the $ to converter, cam & springs.
ARC
57
02-21-2022 10:54 AM
rednekferlife101
32
01-08-2016 10:42 PM
ss454327
10-17-2015 03:43 PM
slowlsx
08-10-2015 05:33 PM
rudvirus
08-05-2015 08:05 PM
Quick Reply: 09 Sierra 6.2 1 3/4 vs 1 7/8 Headers
