09 up 6.2 Kooks guys come in
Old 09-16-2011 | 04:45 PM
  #61
GMCtrk's Avatar
Originally Posted by ramairroughneck
The header flanges, collector ball flanges, and the factory catback connection are leak free but I have a ongoing problem with the slip fit connection on the ypipe. I have varied the tightness on that connection but just cant get it to seal. I am thinking the only answer is to have it welded up. It is fully slid together and tight. Do you guys have any tips?
Wrap the joint in aluminum foil.
Old 09-16-2011 | 10:07 PM
  #62
ramairroughneck's Avatar
Thanks I'll try that.
Old 09-16-2011 | 10:32 PM
  #63
GMCtrk's Avatar
If you are using a Torca clamp, they should only be tighetened to 45 lb/ft. If you've done more than that, or haven't used a torque wrench, you may have deformed the joint.
Old 09-17-2011 | 03:44 PM
  #64
Ended up seperating the pipes, coating them in high temp copper sealent and then reclamping them together. Fingers crossed.
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: 09 up 6.2 Kooks guys come in
