160 Thermostat in 09 Silvy (need help, answers please)
#31
Wearin' da big hat
Maybe at idle sitting in traffic, but at cruising speed there should be little to no difference in IATs and ambient temps once the MAF can recover from heat soak. Also, underhood temps are influenced by exhaust manifolds/headers far more than an upper radiator hose. We're talking 400+ degree temps radiating off of 8 pieces of metal on either side of the engine bay. Ever been around a car/truck with painted headers? Those suckers put off some heat!
Also, the rear view mirror temp sensor is not the most accurate measure of ambient temps as it is mounted near the radiator (and tranny cooler if equipped/added). I have taken many logs using EFIlive and I have seen near ambient temps plenty of times as long as the weather isn't 100+ degrees outside. I have a CAI and the plate removed from the passenger side under the filter element, so plenty of fresh air gets a chance to make its way into the engine bay.
#32
higher than IAT.
I was not trying to get into a hair splitting competition here. My basic point was that coolant temp directly affects IAT. I kind of think of it like a charcoal BBQ. When you crank the arm and raise the coals closer to the meat it cooks faster and hotter. IE: hotter IAT temperature reading.
#33
13 Second Truck Club
Good debate...
I tend to think coolant temp at least marginally affects IAT's especially @ idle/park. But like 00ChevyScott & white1 mentioned a good CAI that pulls in air from the fender well or outside would be less noticeable.
#34
I am however very interested in how a thermostat that opens 15-30 degrees cooler is going to affect the temperature of the air going into the airbox, through an air filter into a MAF.
#35
As far as I understand, the way these trucks come from the factory, they are designed to run at hotter temperatures to promote more complete combustion, and minimize condensate build up in the oil.
#37
I put a stock airbox on my truck when i took the turbo off. My IATs are within 1* of what my rear view mirror shows once i get to moving.
Ive done the BB mod and besides a not so warm heater in the winter i couldnt tell a diff.
I had a k&n intake before the turbo and all it did was suck in really hot air all the time.
Now that its hot again i might put the bb thermostat back in and play with the tune some.
#39
Originally Posted by Mrgoodwrench3;
In extreme heat I see the ambient temperature much
higher than IAT.
higher than IAT.
im still trying to figure out how your IATs are lower than the ambient temperature.
Only way ive been able to do that was with replacing my heat exchanger with the heater core and running the AC so the Ac was chilling the water and lowering my IATs when i had the turbo setup.
I modified a stock thermostat and put it in my truck friday. Normal ECT has been 195-200*. With this thermostat the ECT has been 165-173*. But the IAT has still remained 1* from ambient.
#40
SlvrSierra4.8
10-01-2015 09:39 PM
