2/3 drop how do I do it? 2012 Silverado 1500 4X4
that's my 08 4x4.
It has 2 in ground force spindles, 2 in shackles and blocks removed.
It sits with a slight front to rear rake, higher in the rear.
The wheels are Black Rhino's and tires are Michelin at2 285/55/20.
No need to change shocks and it is an easy install at a good front end shop.
You will need the alignment checked after.
If you change spindles and not springs or struts you retain your factory ride.
I have done the same suspension change to 3 nnbs trucks and have had no driveshaft vibration in any of them.
My 2010 has the same suspension and GM 20's with 285/20/20 toyo's
doubtful though... belltech is like the edelbrock of suspension... they'll always be around.
