2/3 drop how do I do it? 2012 Silverado 1500 4X4
Old 09-29-2012, 11:58 PM
JCunningham's Avatar
how bad is the turning radius reduced? I was offered a really good deal on used ground force spindles and DJM shackles
Old 09-30-2012, 12:00 AM
Originally Posted by Allgonoshow
that's my 08 4x4.
It has 2 in ground force spindles, 2 in shackles and blocks removed.
It sits with a slight front to rear rake, higher in the rear.
The wheels are Black Rhino's and tires are Michelin at2 285/55/20.
No need to change shocks and it is an easy install at a good front end shop.
You will need the alignment checked after.
If you change spindles and not springs or struts you retain your factory ride.
I have done the same suspension change to 3 nnbs trucks and have had no driveshaft vibration in any of them.
My 2010 has the same suspension and GM 20's with 285/20/20 toyo's
your truck is insparational. I love it. Thanks for the details. I think my truck will look great with a 2/3 drop
Old 09-30-2012, 12:06 AM
Originally Posted by AUTOT3K
just to reinforce what I said earlier.
heres where you'll be sitting at 3" drop without cutting bump stops
and here's where you'll be sitting cutting off the 1st groove, rides like factory again. dont make my mistake haha, do it this way the first time!!
thanks
Old 09-30-2012, 10:35 AM
Fiveminutes's Avatar
belltech adjustable struts here.
rides like factory
i cut 2 grooves on my bumstops
no vibrations but i think the pinion angle is off
Old 09-30-2012, 11:07 PM
rides like factory
do you have any pictures of your truck?
Old 10-01-2012, 08:27 PM
Old 10-01-2012, 11:21 PM
looks like the truck should be
Old 10-02-2012, 12:53 PM
oh its set at 1" in the front btw
didnt want that much rake
Old 10-05-2012, 12:46 PM
i ended up going GF drop spindles because then the drop wont be a wear part. What if they discontinue the drop struts? Then id have to do it this way and buy new shocks.
Old 10-05-2012, 02:11 PM
rcsb jon's Avatar
you think the same way i do... haha.
doubtful though... belltech is like the edelbrock of suspension... they'll always be around.
Quick Reply: 2/3 drop how do I do it? 2012 Silverado 1500 4X4
