2' drop shackles, no bed trimming/removal needed.
Hey guys
I had been reading that the bed needed to be trimmed or lifted a few inches. Nonsense lol. Buddy of mine and I had remembered a trick that worked on my obs, worked here to
With the truck on jack stands, unbolt the shackles and remove the bottom bolt(if you have a hitch, it needs to come off)
Whatever side your working on, put a jack on the opposite side shock mount, get a friend to start jacking it up, while you watch the leaf spring, use a pry bar to guild it to the side of the pinch weld. It will clear it and you can push the bolt through and drop the old shackle out. Repeat on the other side.
Took me about 45 minutes start to finish. Dropped my ccsb 2 inches, I'm gonna remove the lift blocks an that should get it completely level.
Hey guys
I think I'm following along here, an interesting approach for sure! I've installed drop shackles on my last two trucks, and if I don't do a flip with this one, I'll try your method when installing my next set of shackles.
Yes sir, support the frame so th axle can move freely.
Basically your going to tit the axle, guild the side of the spring pack your working on to the side of the pinch weld. Works like a charm
1 Post
I didn't have to cut any lip or remove the bed on mine either. I did the same. Lifted the spring up to remove the bolt.
However if you have a factory hitch. You gotta drop that to get a bolt out on the passenger side
I had to bend the pinch lip of my bed when I did the shackles & removed the factory block. Under its own weight the shackle itself was lightly rubbing the pinch lip, causing a slight squeeking sound.
murderedSS
27
10-12-2015 11:13 AM
mitchellmade
09-27-2015 08:25 PM
Stainless Works
09-03-2015 08:31 AM
