2008 Silverado Won't start - cranks, fires, runs, then dies
Old 01-29-2016, 01:53 PM
Tootall's Avatar
Default 2008 Silverado Won't start - cranks, fires, runs, then dies
I did a turbo kit, 80e swap and cam install on a 2008. Got everything bolted back and ready to go, and it won't stay running.
It's still on the previous DOD delete tune from a previous cam swap, along with the 60e tune
My question is, is the segment tune for the 80e a must to make it "run?" I'm just wanting it to fire up to check for leaks.
When I crank it and runs for 1-2 seconds and dies, it has 40+ psi oil pressure. I deleted both VATs, but I haven't verified that the fuel pump is being killed.
What am I missing?
Old 01-29-2016, 01:58 PM
I have a gauge for that
Atomic's Avatar
How different is the cam? Both coil packs plugged in? No you shouldn't need have to do the 80e segment for it to start and idle. Try adding 15% to the base running airflow table to see if it stays running.
Old 01-29-2016, 07:57 PM
Tootall's Avatar
OK
Old cam was 224/230 .581 .592 -110
New cam 228/232 .601 .595 112
Old 01-29-2016, 09:50 PM
Atomic's Avatar
Thats close enough it should idle just fine...when it starts does it surge then die or just kind of stumble then die?
Old 01-30-2016, 08:18 AM
foxnutz's Avatar
Have you checked the MAF sensor or wire running to it. If it is speed density, sometimes the e38 will not fail the MAF and switch to speed density.
Also I ran my 4l80 with the 4l60 tune. I drove to a guy to write the 4l80 tune before I had EFI Live. It just puts it in limp mode (2nd gear only).
Old 01-31-2016, 09:51 PM
Tootall's Avatar
it runs and then shuts off as if you're turning the key off. Fuel pressure stays at full PSI, it does not drop
Also I ran my 4l80 with the 4l60 tune. I drove to a guy to write the 4l80 tune before I had Eli live. It just puts it in limp mode (2nd gear only).
I hooked up the MAF, but it's the same, with or with out it.
Old 01-31-2016, 09:53 PM
Tootall's Avatar
here's the tune and the log that I'm using.
I did not tune this truck, it was tuned by a local guy named Chuck Anders.
File Type: hpl
Old 01-31-2016, 11:01 PM
Tootall's Avatar
here's what it's doing
Old 02-01-2016, 06:58 AM
Atomic's Avatar
Looks like it needs more fuel in it. O2s didnt even flinch, they should go pig rich on a cold start.
They are hooked up, correct?
Old 02-01-2016, 08:04 AM
Tootall's Avatar
driver's side is, and the passenger side is not. It's getting WB tonight.
Quick Reply: 2008 Silverado Won't start - cranks, fires, runs, then dies
