2010 Denali Underdrive pulley PROBLEM!
Old 04-20-2010 | 10:13 PM
97 Z Me Go's Avatar
11 Second Club
Default 2010 Denali Underdrive pulley PROBLEM!
Long story shot took my asp under-drive pulley off of my 06 5.3. Should fit the 6.2 so i went to go toss it on the other day when I realized it has that dang stretch belt for the AC. Anyone encounter this and what did you do?
Old 04-21-2010 | 06:01 AM
markislive78's Avatar
13 Second Truck Club
2010 Camaro is the same way...good read here... http://www.planetlsx.com/tech/How_To..._Camaro_SS/105
I guess u gotta guide that baby on like guiding a chain back on a bike sprocket...
Let me know things work out I still need to swap mine....I bought the SLP pulley w/Dayco 5040345 & 5060895 belt's...pulley came with a new crank bolt..
Old 04-21-2010 | 07:41 AM
iamkeniff's Avatar
just put a tentioner like the 08s...its got the bolt holes for
it an run a longer belt
Old 04-21-2010 | 08:13 AM
skipperdaddy's Avatar
yep encountered this last night... i got the belt off, but idk if im gonna fight it, the holes are there i may go buy a tensioner and a belt for an older truck...
Old 04-21-2010 | 07:18 PM
bad intentions's Avatar
i just added a tentioner to mine and solved the problem
Old 04-22-2010 | 09:12 AM
yep, adding a tensioner and the longer ac belt... to hell with all that "stretch" belt junk...
Old 04-25-2010 | 08:52 PM
Mrgoodwrench3's Avatar
The correct length belt can be a pain to install on stock or underdrive pulleys. I just work it on one rib at a time over the crank pulley. The problem with running a longer belt is that the AC tensioner does not put much tension on the belt. They tend to slip.
Old 04-26-2010 | 03:09 AM
supercharged680's Avatar
u guys im thinking of installing an underdrive pulley for my denali what parts do i need exactly.. havent changed a pulley in my life lol never actually believed in its power.. but im trying to get a better 0-60 time so yah... so i need the UD pulley obviously what else
Old 04-26-2010 | 03:29 AM
FrankyRST's Avatar
UD pulley, new crank bolt, smaller alternator pulley, 2 new belts....I believe thats it.
Old 04-26-2010 | 03:34 AM
FrankyRST's Avatar
I ran into this problem too. I just added the ac tensioner and I was good. I ac belt does slip every now and then though...
UD pulley, new bolt, smaller alt pulley, two new belts...I think thats it
Quick Reply: 2010 Denali Underdrive pulley PROBLEM!
