3200 stall...Retune?
Old 06-27-2011, 06:50 PM
red_silver's Avatar
Default 3200 stall...Retune?
Just wondering if I change the converter in my truck am I going to have to do a retune for the truck? thanks.
Old 06-27-2011, 06:52 PM
2007chevy5.3l's Avatar
Yeah I had to change quite a few settings in my trans tune for my circle d 3200
Old 06-27-2011, 06:54 PM
Mod with training wheels
smokeshow's Avatar
That converter is quite a jump from the stock one. So yes, it will need a retune.
Old 06-27-2011, 06:58 PM
red_silver's Avatar
Thanks good to know. Now is this something I can do with my diablo tuner or am I going to have to get a custom tune? Another Question my buddy has a converter but we don't know the stall is there a way to find out?
Old 06-27-2011, 07:08 PM
If the Diablo can change the torque converter clutch lockup parameters then yeah you could probably use it. But honestly id get a custom tune
Old 06-27-2011, 07:21 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You'll likely need to deal with some DTC's to prevent the transmission from going into "limp" mode. With a 3200, when you launch it, the PCM often thinks the transmission is slipping, and cranks the line pressures to max, and locks the transmission in either 2nd or 3rd(cant remember).
Old 06-27-2011, 07:52 PM
smokeshow's Avatar
To start, changes in shift points will need to be accounted for, and timing changes since you'll drop to a lower part of the spark table faster.
Old 06-27-2011, 09:46 PM
KY_BOB's Avatar
Been there, done that. I kept getting shift solenoid codes and the trans going into limp mode after installing my last converter in the AV. I killed them with HPT, no problems after that except it felt like it needed a little higher shift points. The converter was still very loose feeling when it shifted so I bumped them up a hair.
Old 06-27-2011, 11:23 PM
Yep. I just don't know if his Diablo handheld will have the power that he needs. I doubt that it does, but I'm not positive.
I'd recommend HPTuners or EFI Live, or a custom tune from one of our sponsors.
Old 06-28-2011, 03:46 AM
j_ahlheim's Avatar
x2 get a tune from our sponsers...I know because I tried the Diablosport first and then got a tune from Justin at Blackbear. Night and day difference.
Quick Reply: 3200 stall...Retune?
