4.10 or 4.56 for the track?
I run a 4.88 in the 4l60 and ecsb and its about perfect on a 4.8 truck with 33" tire. There is still enough load with a 2800 stall I bet I could use a turbo setup without spooling issues.
To the OP
If your going turbo then keep your current gears. They are a great ratio for a turbo. A custom tune is the very first thing you need. I believe Nelson Performance had a build just like yours a while back that in basically stock form with a tune dropped close to a full second in the 1/4. I would say a tune would help you a ton!
ok so ill keep the 3.42's for now.
I just booked an appointment for a tune at the local dyno tuner here in Edmonton. soonest is june 17th.
if I can buy a 3000rpm stall by then I will.
$750 bucks for a tune and $150 an hour for any other tuning I want done afterwards with future mods.
srems kinda steep pricewise but that's how it goes in Alberta.
