4.10 or 4.56 for the track?
Old 05-13-2013 | 10:31 PM
oakley6575's Avatar
What size tire are you running?
Old 05-14-2013 | 06:52 AM
james8997's Avatar
The first gear in the 6 speed is very low. I pull a 2.09 60' in a ccsb, stock 3.42s
Old 05-14-2013 | 07:24 AM
97aztecgt's Avatar
I agree with James, fist gear isn't really all that long in the 6 speeds. Especially compared to the 4l60.
Old 05-14-2013 | 08:27 AM
Gus 82's Avatar
I run a 4.88 in the 4l60 and ecsb and its about perfect on a 4.8 truck with 33" tire. There is still enough load with a 2800 stall I bet I could use a turbo setup without spooling issues.
Old 05-14-2013 | 08:45 AM
gamble686's Avatar
A turbo would spool just fine yes, but building boost off the line without pushing through the brakes would be tough.
To the OP
If your going turbo then keep your current gears. They are a great ratio for a turbo. A custom tune is the very first thing you need. I believe Nelson Performance had a build just like yours a while back that in basically stock form with a tune dropped close to a full second in the 1/4. I would say a tune would help you a ton!
Old 05-14-2013 | 08:53 AM
nonnieselman's Avatar
yes a tune by itself would get you in the 14s i bet.
Old 05-14-2013 | 05:18 PM
craigsix's Avatar
ive got a 2012 rcsb. 5.3 6speed. boltons and 3200 stall with 4.10s 30.6 inch tire im in 4th gear over 5500 rpms out the back door.
Old 05-14-2013 | 08:11 PM
roland1's Avatar
what times are you running?
ok so ill keep the 3.42's for now.
I just booked an appointment for a tune at the local dyno tuner here in Edmonton. soonest is june 17th.
if I can buy a 3000rpm stall by then I will.
$750 bucks for a tune and $150 an hour for any other tuning I want done afterwards with future mods.
srems kinda steep pricewise but that's how it goes in Alberta.
Old 05-14-2013 | 08:22 PM
97aztecgt's Avatar
$750? Wth?
Old 05-14-2013 | 08:23 PM
roland1's Avatar
my 60' is consistantly 2.4.
perhaps elevation is the culprit.
I'm at like 2200 ft.
Quick Reply: 4.10 or 4.56 for the track?
