4 speed vs 6 speed
Old 12-01-2011, 10:28 PM
  #21
chevrolade's Avatar
I broke two 4 speeds ,before i finally went 6L90e....and dont regret it ..thing pulls hard.
Old 12-01-2011, 10:51 PM
  #22
GMCSIERRA5.3's Avatar
Whats the difference in.6l80 and.6l90
Old 12-01-2011, 11:26 PM
  #23
iamkeniff's Avatar
Bigger parts, harder parts, bigger slip yoke and u joints. It comes in a 2500 or a 3500 im no sure
Old 12-02-2011, 05:28 AM
  #24
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Wonder if the 90e would be a viable swap for the awd guys. Wonder if the output shaft is the same as the 4L80e trans and if the awd tcase uses the same style input gear as the older half ton tcases.
Old 12-02-2011, 07:40 AM
  #25
sand man's Avatar
the 6l90e is a simply put a better version of 6l80e
down side that its heavier, harder to find, not much upgrades out there for it yet
so i would stick with what every body has and built to save my self money and tests
a friend of mine broke 2 90e's and he has a stock motor,stock tune
and the truck that never had any hard time at all
Old 12-02-2011, 09:08 AM
  #26
My opinion...if you want a 6spd truck, sell yours, and buy a different one. It just isn't worth the hassle and $$ to do a conversion.
As for the pros/cons...The 6 speed is better in every way, especially with the 5.3...It needs those closely spaced gears. I've had a 4spd 5.3, 6spd 5.3, and now a 6spd 6.2.
Old 12-02-2011, 10:14 AM
  #27
i want to do it real bad lol only thing stopping me is the dam engine harness lol i bet its a bitch to put in
Old 12-02-2011, 11:56 AM
  #28
cam
cam's Avatar
I build swaps all the time but I have to agree with this. The real problem with these gen IV set ups is the TOS and computer network connections always seem to be wrestling with each other instead of working in perfect harmony. There are work arounds but the head aches are not worth the gains for only a trans swap IMO.
The real advantage of the 6 spd is the 1-4 gearing is nice but aside from that the 5-6 is bupkiss. The final drive ratio is the same so there is not overdrive advantage and a good built 4L60E can do the jon for sub 500 whp and a good quality stall will quickly eliminate any hole shot advantage the 6spd offers plus the go fast parts for the 4L60e are a hella lot lower cost the the 6L80e.
Dont mistake what Im saying as the 6L80e is a nicer trans but I think it would be better to simply sell and buy a truck with one than try and swap one in your current truck now.
Old 12-02-2011, 11:57 AM
  #29
iamkeniff's Avatar
I have what a performabuilt level 2 would cost with a converter (4L60e) in my 6spd swap and thats with a custom 2 peice driveshaft and a custom carrier bearing mount made by Madman. The swap is just as hard as installing a 80e. I finished my swap in 3 days after i got all my parts through the dealer. Selling his truck and jumping into a new one is easy unless you are like me and decide to BUILD what you want and not BUY what you want. Besides who says he'd be able to break even or gain a little on selling his truck? If you trade it in you are really going to get screwed over bc the truck is already modified past warrenty.
The harness is EASY as hell to install. If you can change your own brakes, drop your own truck, install a converter you can handle this swap. IF YOU CANT DO **** THEN PAY SOMEONE!
Read over my swap thread, it explains EVERYTHING to a T with pictures damn near. Also you can pm any questions you have. Plus the swap is pretty straight forward if you buy the correct year harness. The ecm will send the tcm the things it needs so no need to deal with the tcm being reflashed like i had to.
Just my .02 take it how ya want.
Old 12-02-2011, 11:00 PM
  #30
Thanks niff pm sent
Quick Reply: 4 speed vs 6 speed
