5.3L 4L60E TO A 6.0L 6L90E Swap
Ok so here is the rundown.
Swaping my 5.3L 4l60E to a 6.0L Forged internals mated to a 6L90E
Engine will be shipped 07/25/08 for forging.
6.0L Gen IV Block with L92 heads. Dont know if its VVT or not
If its a VVT, It will be removed, block will be prepped for 12 psi.
Rods, pistons, cam, heads from local guy whos really good
Set up for 6500 rpm redline.
TVS 1900
Tranny update. its being replaced, a new tranny is on its way
6L90E will be bolted up after the engine goes in and is broken in.
Needed items are crossmember and driveshaft.
Programming will also be needed.
Goals, are high to mid 11's with street weight and slicks.
Needs to be a daily driver.
Updates will be made with pics and other information will be posted. I want everything to look like its stock so money will be spend and dreams might be crushed.
Stay tuned...............................
If you guys have any pointers any help anything will be appriciated. Thanks
TVS 1900
Tuning + harnes for the tranny to be mated up to the engine, and getting the bcm to accept all the futures the tranny has. My main concern is getting the gears to work once that is done, the rest ill waite untill 09 when the trucks to finish the rest of the body control ****.
05GMC4.8
08-07-2015 09:55 PM
oharajo
07-18-2015 09:24 PM
Nimoryan
07-05-2015 03:50 PM
