6.2 check engine light
Ok so I put a volant cold air kit on my 11' 6.2 and after I drove about 100 miles the check engine light came on.... Disconnected battery to reset the computer and it came back on after 100 miles or so.... Anyone have any problems with this kit and/or have any suggestions?
Haven't really noticed any difference but I haven't really got on it yet truck has only 1300 miles..... Will take it and get it scanned as soon as I can get to a shop just wanted to see if it is a tuning deal like it is running to lean cause of the kit
I had the same problem! Check every single connection. Might even take it off and put back together extra careful! Make sure all clamps are tight and leak free. Mine had a broken hose clamp then i had the tube too close to the throttlebody and it pulled the tube off at the airbox. Slowly but surely bud!
you might even have to get it tuned as i was still running a bit lean and had to richen up my fuel to +5
i had this problem with my 2011 denali i have the k&n and light kept coming on every 100 miles or so but the bad news is i noticed after the intake it got sluggish called a local speed shop and K&N both told me for 2011 u will trigger ur ecm so u have to tune it in oder to get any HP gains and the worst part was i got mine back in October and no tunes from HPtuner had an upgrade for the 2011 yet
Yea I have been told that once it is tuned it will go off.... Just dont want to tune it till atleast after the first oil change... Guess I will put the stock box back on till I get 3000 miles
