6.2 ordered a converter
Old 08-28-2011, 01:18 PM
  #31
8UALIVE's Avatar
Originally Posted by SICKSIXTYSEVEN
Lance, I told Chris at circle D that i do tow and my trailer/car/and load is not light. At least 6000lbs. He pretty much said it wont be a problem. Yes the converter has to be locked up to be efficient. right now i get around 16.50 average mileage on the highway. remember i have 3.73 with 28.8 inch tall tires. when i cruse at 2K or under i get good mileage. 2K and over it drops off.
RJWZ i was def hoping for some sub 13.5 passes. i would love to see 13.2 i will be the first to let you know!!!!!!! I may also get an underdrive pulley on there before hand from SLP as well. who knows if that will do a damm thing.
Let us know when u get it in!! I'm interested in the same set-up!
Old 09-03-2011, 07:52 AM
  #32
LS1 Tech Administrator
Patrick G's Avatar
Free bump. In for the results. Chris makes a really nice converter.
Old 09-16-2011, 05:50 PM
  #33
SICKSIXTYSEVEN's Avatar
converter is in!!!!!
like i said its a Circle D multi Disc. I told Chris 2800-3000 stall and that i tow!! It's looser than I though but not to bad. My tuner also adjusted the part throttle shift points up because he noticed how the truck lugged in 6th gear at 40MPH before the converter. i def need a bigger tranny cooler, truck is now seeing 208 temps and averages 187 or so. 1st gear is useless on stock tires lots of smoke and also flashes the converter the highest due to the steepest gear. 4WD launches are amazing its def on par with a stock evo or sti.
i will be going to the track on 4 drag radials on October 10th i hope to hook in 2WD but the 4 will be on just in case and to save weight over the stock tires. stock tires were 31.7 ( on the truck now ) and my radials are 28.8 on centerline billet wheels 18 inch. i will also be changing to a 6L90E filter and AMSOIL transmission fluid.
i will keep you guys posted on track times ASAP.
Old 09-16-2011, 06:02 PM
  #34
GMCtrk's Avatar
245 or 258mm?
Old 09-16-2011, 09:04 PM
  #35
Banned
pl4yboy's Avatar
Originally Posted by GMCtrk
245 or 258mm?
I'd venture to say 3200 if he tows. Chris wouldn't let me get a 245 since I tow, and I tow less than this guy I'd be willing to bet.
I am really upset that you're having such temperature issues. Get a Tru-Cool 40k and they'll go way down. My 258mm 3400 has temps around 150 or so in 100* weather. Tonight it was 60* driving home and I never saw over 120*.
Old 09-16-2011, 09:10 PM
  #36
GMCtrk's Avatar
how do you like that 258 3400? I wonder how it would compare to a 245 3400 in track performance
Old 09-16-2011, 09:51 PM
  #37
traveling mod
andrew383's Avatar
Hook the trailer up and tell us what happens
Old 09-16-2011, 11:22 PM
  #38
Banned
pl4yboy's Avatar
I love my 258 3400. When I ordered it I told Chris I wanted something LOOSE as hell. This thing barely moves til it hits 2800 RPM. The 245 is going to be less rotating mass for sure.
Towed about 4500#s last week. 90 degrees and temps hit around 185.
Old 09-17-2011, 08:47 AM
  #39
traveling mod
andrew383's Avatar
What did it flash to from a dead stop with the trail hooked up???
Low speed driving is what im worried about in picking mine out
Old 09-17-2011, 10:26 AM
  #40
06 4.8's Avatar
Im becoming aggravated with you.. WE NEED WOT VIDS!!!!!!!lol
Quick Reply: 6.2 ordered a converter
