6.2L Redline
I believe the first to second shift is raised to 6200 RPM and Third to fourth is like 6k or so, anyways I believe that rev limiter can be set safely to 6300. Maybe Wheatly will chime in on the matter.
With the stock cam, I had mine set at 6400 and the 1st to 2nd shift at 6100 and the rest at 6000. I have the limiter set at 7100 now and it shifts 1st to 2nd at 6800-6900. Its the stock valve springs that are the limiting factor.
