6 speed conversion?(6l90e)
No you can infinitely flash the bcm but if it's not uplevel the tu/td switch will not function.
But the 6 speed tu/td capability is only available via the uplevel bcm. If you have an slt or ltz or power fold mirrors it already has the uplevel BCM
It's a internal software difference.
Tin Foil Hat Wearin' Fool
Anyone know if the output shaft on the 6L90e is the same as the 6L80e? I dont believe it is and Id probably have to go with a HD electric tcase but I have no idea if my half ton autotrac rotary switch can make the HD case function. Would be cool to swap in the a 90e instead for the added strength since this thing is going to get a bit of power put through it eventually
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
Make sure the spinny thing is up front in the engine compartment not out back by the rear axle..........those rear mounted spinny things suck, been there, half reworked the kit and sold it off (of course it was a C5 application not a truck but it sucked horribly, total dyno queen)
