6 speed conversion?(6l90e)
#42
We are using the 07 denali 2wd VIN software loaded into the factory 08 5.3 pcm. Controls the 6l90e just fine.
Truck runs and drives with no issues. No repinning was needed at all, only extended one connector for AC pressure switch to reach and the harness was plugnplay.
I used the same year denali vin in my truck worked great.
Its good to know that my theory for using a denali harness would work
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
#44
FormerVendor
Street tuning today, runs and drives great. Adjusted so it should make the shifts even when you change to the short 28" tires without messing with the tune.
I think the truck is good to go for some bottom 12 sec passes. I'll check if I've got any pictures to post up
#45
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
