Advice on Fuel system upgrade
Old 12-27-2011, 08:53 PM
ivan_key's Avatar
I'm not messing with the rings on the motor in the truck, ill do that to the spare motor, I have arp head studs and a ls6 cam and thats about it on the motor
Old 12-27-2011, 08:58 PM
62nalide's Avatar
you should be good then keep me posted id like to know what psi you at and some numbers on them nnbs 4.8s
Old 12-27-2011, 09:45 PM
ivan_key's Avatar
Will do, ill be running a 78mm turbo top mount, just have to figure out the fuel system and ill see what it can do
Old 12-28-2011, 12:31 PM
mnm8977's Avatar
Aeromotive also makes a pump that is compatible with the PWM signals from the FPCM. Part #'s 11140,41,42. Not sure they are 100% compatible, but may be worth looking into. It flows 340 lph.
Old 12-28-2011, 01:28 PM
Area47's Avatar
fwiw, they are not e85 compatible.
MS3Z
07-30-2015 06:17 PM
sauldgold
07-23-2015 02:15 PM
4B11T
07-13-2015 03:48 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: Advice on Fuel system upgrade
