Another 6.2 exhaust thread
To RedChevy4x4
Here is what I did with my tail pipe. 6.2
Very keen observers will notice the inlet pipe is 3" not 3.5
I had a hard time getting the noise level to my liking after installing my headers, ended up
with 3 inch Dynomax catback.
Regardless, before I changed the catback I modded the oe stuff to look just about the same as this pic
wow found a pic
this is cutting out the oe resonator and welding on the tip in the pic.
easier said than done,as you need 3.5 tubing which I had [from doing other trucks.]
Basically, I used pieces of oe 3.5 tubing to make this line up. Cut/weld
Truck is on a lift, wheels hanging, looks like the spring is touching , but not even close when it's
on the ground.
wow found a pic
on the ground.
GXPJAY
02-13-2022 08:15 AM
