Anybody got a Beltech 4/7 Drop on there NNBS?
Have you looked into Dynabeads? There like little lead(i think) pellets you put in through the valve stem, if the tires mounted, and allows for ballancing on the go. I have used them for off road applications with great results, and I have a few buddies that use them in their bikes. Nothing but great results.
I'm not and 6" in the back is as low as I'll be going. I cut the factory bump stop mounts off and relocated the bump stop to the frame. There's still a good 3-4" between the bump stop and axle. I haven't had time to test it on a bumpy road yet
7" is fine for the standard cab short beds, the extended cab and crew cabs sit slightly lower, so most prefer helper bags or a notch, or both at 7". I only bottom on on some nasty pot holes with mine.
