Anyone with a 2009-2013 6.2L Flexfuel w/Cam Only?
LS1Tech Whore
Those of you with a 2009-2013 6.2L Flexfuel Engine and cam only, did you have to swap to bigger injectors? Trying to see if the factory L9H injectors are big enough for a mild LS3 cam swap and still be able to run E85. HPTuners data shows about 50 lb/hr @ 58 psi. My current 5.3L LMG shows about 36 lb/hr @ 58 psi. Just trying to figure out if I will need bigger injectors than the L9H stock injectors.
rednekferlife101
09-14-2015 05:27 PM
Gmc_sierra
09-13-2015 10:02 PM
