best way to get 5-6" drop on back?
planning on dropping the truck but cant decide how to go about the back. last time i went 4-7 on my 08 rcsb, but on my ccsb i either want to go 3-5 or 3-6.
on front i plan on doing spindles and belltech struts, but how should i go about the rear.
plan on running 285/40-22's up front ad 305/40-22's on back.
still want a good comfortable ride and looking for something that will be the best when it comes to traction when i start modding the new 6.2
I'm doing the exact same thing in my CC.
Front spindles and belltech adjustable shocks.
My plan for the rear is, I ordered a DJM 6 inch flip kit and the I have ground force 1-2 inch drop shackles which when reversed should make the kit adjustable to a 4 or 5 inch drop.
I also order shortened rear shocks.
Let me know how the different size tires work. The ABS may not like the size difference. I'm running 285/50-20's all the way around right now. I want to run 295/50-20's in the rear and 285/50-20's on the front but don't know if the computer will allow it.
you'll be fine up to about 1-1.25" of difference. my 08 had diff. size tires on front and rear and i had no problem when it was about a 1.25" difference
the only tiem i had trouble was when i was running 285/35's up front and 305/40's on back. which was 1.7".... i only happened like once a month or so, the abs light would come one and the brakes worked fine but abs was de-activated. all i had to do was turno it off for 5 min or so and it was fine
for front i would do
2" spindles and coil relocator(cheaper than belltech struts)
rear
you don't have much of a choice but to do flip w/ hangers
flip and air shocks, and just air up to provide the lift.
leaf springs, hard to find, expensive, reduce payload
but luckly i found you some
http://houston.craigslist.org/pts/1701997188.html
not sure if you really want to run that size tire, you will have some gap if you do 3/5
this is mine with 275/45/22 on 22x10 wheels on a 4/7
rear
TX Tahoe Z71
09-01-2015 09:11 PM
silver-mod-o
18
08-25-2015 08:18 AM
GMCSIERRA5.3
08-07-2015 01:50 AM
Mossyoakglock
07-17-2015 08:30 AM
