Cal-speed headers
Please do find the pics. i live in MN and have similar conditions for salt and snow, i went with the ARH for this reason and for quality. Not saying I didnt consider the Cal-speed 1 7/8" because I definately did for the cost, but they dont have a 4x4 model yet. One thing to combat this issue and what I intended to do (with cost difference between ARH and Cal-speed) if I went cal-speed route was to have them ceramic coated to prevent the winter elements destroying them. Anyone have experience with header wrap in winter conditions? Would that help the header longevity? Sorry to change the purpose of the thread from fitment to product quality. Just a consideration if quality is one of your concerns.
I would advise against the wrap since if it gets moisture or anything in there it's going to be like a rain forest with all the heating and cooling and reek havoc on them.
Ill browse his Photobucket.. I think he has a picture in there.
And also I am 4x4 so that's the other reason I am steering away from Calspeed.
Last time I put headers on a truck I had them coated and they were great. Some manufacturers will tell you they'll void the header warranty if you use a wrap, I don't know about Cal-Speed.
I think (could be completely wrong) if anyone is 2WD and determines Cal-speed is the way to go and they live in a winter climate or plan to do ORY themselves to make them fit a 4x4 (if possible) I would suggest they seriously seriously consider ceramic coating them even if they are stainless. I had high temp painted and baked LTs on my 350 jimmy. Paint took a beating from the salt and winter and i ended up with headers that looked worse than stock mantifolds in terms of rust. They were not stainless of course, but if i did it over i would have had them coated and not worried about it.
I had ceramic coated headers on a 454 and they made a HUGE difference from the cast iron factory manifolds. I've seen tests in magazines also where they showed a big reduction in header surface temp and underhood air temp.
