Cam ???
Old 05-02-2009 | 11:16 PM
08slammedrcsb's Avatar
yes i will, can't wait to get cracking, im gonna try to run down to my tuner tuesday night and have the DOD turned off. One of my buddies who works for redline motorsports very good wrench w/ ls stuff is helping me w/ the swap, how long should it take w/ an experienced helper?? He seems to think only afew hours.
Old 05-03-2009 | 09:28 PM
Noah Burns's Avatar
depends, I've done about 20 swaps, still takes me about 3-4 hours... thats with beer and **** breaks... plus I usually have atleast one temper tantrum in there somewhere when I **** something up.
Old 05-03-2009 | 09:43 PM
sonoma43's Avatar
a buddy and I dicked around on my swap...took breaks here and there, went and had dinner. in no means rushed to get it done and had it done in 5 hours, and we worked slow when we were working. It's the easiest swap you'll do
Old 05-04-2009 | 05:09 PM
Lama1's Avatar
There is a lot of bad information going on with DOD/AFM cam swaps, and to set the record straight, you have to replace the lifters and trays alog with all the other doo-dads to actually get into the lifters, to make the truck run correct.
Anyone running a cam on an AFM engine with AFM lifters might as well just buy AAA roadside assistance, because you will need it.
Old 05-04-2009 | 08:26 PM
see this sucks, you hear so much different info on this simple swap. Why did Texas speed not tell me i needed all this other bull **** to do the swap???
Old 05-04-2009 | 09:24 PM
Noah Burns's Avatar
TSP probably doesn't know...
Old 05-04-2009 | 09:36 PM
sonoma43's Avatar
TSP told me that you just needed the DOD turned off as well.....
there are many people still running strong like this...maybe some people just had some bad luck????
Im wondering what the deal is with the NNBS and cam swap's are as well now
Old 05-05-2009 | 09:05 PM
LaTampSStyle''s Avatar
well i've been reading all this info and also to be on the safe side what else do i need for my swap?goin with a custom grind from tsp.pushrods 7.4's,springs,plus 3 bolt sprocket.what else do i need to get for my swap guys???help me out aswell!
Old 05-05-2009 | 09:16 PM
amadeospike's Avatar
I had my DOD turned off even befor the cam swap but when i installed the cam it went to crap. My cam was damaged and i had one lifter fail completely. I caught it cause it started with a misfire and it turned out to be a lifter that had collapsed. Well, when i took out the cam it was damaged so i replaced the cam, lifters, and valley cover and that took care of it.
Old 05-05-2009 | 09:19 PM
here is my thread so u can see what can happen if u don't change ur lifters
https://www.performancetrucks.net/fo...d.php?t=431967
Quick Reply: Cam ???
