Cam Help
Old 04-09-2009, 07:31 PM
07 New Body 5.3's Avatar
Default Cam Help
I have a new body 2007 5.3 with a 373 gear and k&n cold air kit and cat back exhaust. so i was wondering what cam i could go with that would help me gain horse power. i have heard a Z06 cam would work and other cams from comp cams. my head casting says 243 on it. so if anyone knows about cams i would be great full for the help. and i need to get a tune to turn of the active fuel mang system off as well. I'm looking for a little bit of lope but good gains. this is one im thinking about going with from comp cams Grind Number: LS1 XR265HR-14
Old 04-09-2009, 07:59 PM
sonoma43's Avatar
use the search function....that will net some gains for what your lookin for
Old 04-10-2009, 12:42 AM
Lama1's Avatar
I am running this one in a aluminum 2008 5.3 formerly with AFM/DOD.
Lunati Voodoo
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 212/218
Gross Valve Lift (Int/Exh): .531/.531
LSA/ICL: 113/109
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-6400
Part Number: 60510
It runs great.
Old 04-10-2009, 03:59 AM
Banned
lucky77's Avatar
Comp cam 212/218 . .58X lift . 112-114 LSA. .. would pull great low End. . .
220/220 ,58X on 112LSA = great cam . . it all depends where u want ur power at*
our NNBS have a 1 bolt Cam ,which means u are limited on cam choices . Comp cam has 1 bolt CAm's . .or u cam choose any 3 bolt cam, and just a 3 bolt sprocket ( ls7 sprocket) which is what most of the NNBS owners are doing. . . dont forget 918 springs + hardened Rods.. if u plan 2 shift above 6200 RPM"s .. Ur 243/799 heads.. are Great LS6 flowing heads. . . . . . .keep us posted on how ur cam swap goes. .
Old 04-10-2009, 07:19 AM
Denali Dude's Avatar
Comp Cam 220/220 .581/.581 114LSA Nice cam pwer range 4000-6300rpm pulls great .
and If you are going with an LS1 cam dont forget to take the 3 bolt sprocket if u want the part # pm me
Old 04-10-2009, 10:34 AM
Banned
lucky77's Avatar
220* . .depends on the tune.. I've seen applications.. that are pulling hard all the way into 6800 .. and the sprocket you can get it at ur local Gm dealer, they run about $30 .
Old 04-15-2009, 11:24 AM
thanks for ur help i hope to get it done soon. ill have to find a good tuner and i can buy that sprocket cheap since i work at a dealership
Old 04-15-2009, 04:01 PM
BLACKND's Avatar
You drive a black RCSB and work at Ron Carter???
Old 04-16-2009, 07:37 PM
yes i do work at ron carter and drive a black chevy
Old 04-26-2009, 12:29 PM
Lama1's Avatar
You'll need wayyyyy more than just a cam, spocket and springs if you have AFM/DOD.
Quick Reply: Cam Help
