Cam issue?
I am having the same issue on my 08 5.3 with a tsp220 112lsa. Mine only does it if i get up to operating temp, get gas or go into a store really quick and i will have to give it gas just to get it to run. justin is still working on it though.....
yeah i was telling htem it cant be the cam cause u sent me pics, today it did it again, i listened for the fuel pump to kick on when i placed the key to run but it didnt. i tried a few times to crank it and it backfired very loudly!!! setting off car alarms. Finally the fuel pump came on and the truck cranked. I am still waiting on a fuel pressure gauge to see the psi. However once the truck starts it is perfect. in the morning truck starts up just fine. only during restarts or if i let the truck sit for 30 minutes or so it has a hard time. Do you guys think i can probably just change my fuel pump to a aeromotive 340 since im going boost, or will i have to get a fuel pressure regulator or tune it for new pump. Just trying to eliminate all problems that it could be. P.S. matt got another guy wanting to do a cam swap!!!!.
If you haven't fixed this, have you checked the cam position sensor? My 99 Camaro does the exact same thing. Or have you performed a CASE learn to retime the crank and cam position sensors? Is your tach working?
zblee
63
06-10-2023 01:25 PM
LCHEE
10-24-2020 04:10 PM
V-seriesTech
07-28-2015 12:31 PM
GreyChevy
07-07-2015 08:57 PM
