cam time for the denali! :) heads or intake worth it?
Old 01-09-2014 | 12:03 PM
  #21
rice eater 03's Avatar
Originally Posted by mej0914
You should be pretty happy with those changes. Wont be able to kick the back end around but not much will be able to touch it at a stoplight. I havent run the quarter yet but im thinkin that my truck 12's with et street drags no problem. I'm 2wd with similar mods.
hell it suprizes a lot of people aready..but I miss the power of the blower..it was fun to pull up next to almost anything vettes vipers whatever at a light and laugh at there faces in the review mirror..lol
looking at your 1/8 times your gonna be close..however these trucks make it hard to calculate 1/4mile times because there normaly have shitty 1/8mile but come alive on the back have so the normal calculations don't add up to be right.
Old 01-09-2014 | 12:04 PM
  #22
Originally Posted by TIM Z
Thanks for the info on the VVT, I'll have to reaserch on what all is needed to delete it , I think keeping it simple and reliable like all the other non VVT cammed LS engines out there is a good thing .
Glad to hear your injectors may be good , nice not to have to mess with the fuel system .
12 flat or lower I like the sound of that for an N/A daily driver !
Cool that zippy is working with ya on the tuning /setup , he knows his stuff ,
He built my first 60e back in '05 when he lived in Muskegon , he's a blast .
So he's got the 6speed shifting good too ?
If ya got any exhaust vids or truck pics post em !
missed the part about the exhaust vids...you mean as it sits now? or once the cam is in?
Old 01-10-2014 | 12:03 AM
  #23
62nalide's Avatar
VVT cams FTW!!!!!!!! Heck I made 427rwhp with a baby VVT cam on the denali waaaaay back then
new VVT cams that are out are outperforming non-VVT cams plus you save $$ if you keep it
500rwhp VVT 6.2L with stock heads
Custom vvt dyno - YouTube
Old 01-10-2014 | 01:22 AM
  #24
01FormulaTA's Avatar
Check out http://www.vincihiperformance.com/
Lots of good options...
Old 01-10-2014 | 04:33 AM
  #25
TIM Z's Avatar
11 sec. Truck Mod
Thank you very much for sharing that VVT delete list , really appreciate it
If I decide to do the delete it will be good info to have.
Keep this updated I'm excited to see how it goes together .
Yeah I'd like to hear how it sounds now with long tubes and that cat back .
Old 01-10-2014 | 08:24 AM
  #26
It's been awhile since I really recearched the VVT stuff but basically how it was explained to me that the VVT is really basically just for emissions .. So it's not worth it
IMO 2 identical cams with one being VVT and the other standard lobe. The peak power is gonna be the same. The theory is that you would make power sooner but I've yet to see any proof of that. And IMO the only way would be to dyno 2 identical grinds. But again if the way it was explained to me is that it doesn't work that way and it's more of a sales pitch for emissions crap
Old 01-10-2014 | 09:47 AM
  #27
62nalide's Avatar
Don't get me wrong your cam is a very good one indeed. But now VVT has come a long way. Most shops even now will not tune one WHY? Because most don't KNOW how. A simple VVT cam swap can net you around 75-110rwhp depending how aggressive you want it. Member Rhino79 on here is the master of VVT setups not to mention he is making over 500rwhp on an L99 through a 6L80E trans and stock heads. The new C7 is all VVT and no way round it. Just my 2 cents. Get on 5th gen camaro forums and the new C7 forums and you can clearly see VVT is dominating the game in a new way.
Old 01-10-2014 | 09:49 AM
  #28
Vortec350ss's Avatar
Emissions and more importantly mileage. They retard the hell out of the cam on the highway and situations like that to make the engine pull less vacuum and make less power... in turn using less fuel.
The problem with a single cam VVT is that while you are creatign a benefit to the intake lobe centerline, you are doing the exact opposite to the exhaust lobe. For instance at low RPM when the cam needs to be really advanced to create a great intake valve timing you are creating an exhaust centerline which is great for high RPM. By the same token as you shift the cam to create intake valve timing that,s better for high RPM you move the exhaust to work better at low RPM.
To say is simply a single cam VVT system is very limited and its like a game of tug of war. One lobe (most commonly the exhaust) is at the wrong place at the wrong time.
Old 01-10-2014 | 09:54 AM
  #29
62nalide's Avatar
The new C7 is VVT and in no way limited in anyway 550rwhp is what they make with VVT setups
551rwhp All Motor C7 Corvette - LMR Stage III Heads/Cam Package - YouTube
Old 01-10-2014 | 10:28 AM
  #30
No I understand what you mean... there is some benefit, but its mostly in MPG. I wasnt saying VVT is no good, but compare it to a dual overhead cam which can rotate exhaust and intake cams separately... in that sense a single in block cam is VERY limited.
I was just trying to explain VVT better for everyone to understand.
Quick Reply: cam time for the denali! :) heads or intake worth it?
