Cam upgrade questions.....
Old 12-26-2012 | 09:13 PM
ncange4's Avatar
Default Cam upgrade questions.....
so I've looked around and read all the threads on cams. I have a 2011 GMC Sierra 5.3L w/DOD. I am looking for a cam for my daily driver. I want something with a performance gain, and a better sound at idle. I dont want anything too loopy, this is my daily driver. I have a Corsa sport exhaust and a K&N intake. I know im going to have to get springs, pushrods, rockers. Do I have to change the timing chain and gears? I will also be in the market for a tune for when the cams are finished. Also does anyone know a good retailer for these performance parts? Any help is appreciated. Thanks.
Old 12-26-2012 | 10:48 PM
iamkeniff's Avatar
No need to change chain, nor gears. Only reason to change gears is if you go 3 bolt cam.
Sdpc is a good place or texas speed which are both sponsers
Old 12-27-2012 | 06:10 AM
skipperdaddy's Avatar
Being an '11 you may need a gear and timing cover because it's probably a vvt motor... Just found out most are.
Old 12-27-2012 | 06:36 AM
iamkeniff's Avatar
Good catch on it being a 2011
Look at your front cover to see if it is smooth with 1 sensor. If it is VVT, there is a plate on the cover right behind the water pump, with 2 sensors
Old 12-27-2012 | 09:25 AM
Area47's Avatar
it's a vvt engine. comp has some smaller cams for the 5.3 vvt engines that are a plug n play deal. aside from springs. texas speed doesn't have a vvt cam small enough for the 5.3 that won't require a stall.
Old 12-27-2012 | 09:55 AM
Gus 82's Avatar
I have a VVT cam that I pulled out since it was a bit to big for my 4.8.. Couple thousand miles on it. You can check it out in the for sale section
GrooveCityZ71
08-31-2015 12:05 PM
BigEd_72455
08-08-2015 07:37 PM
MS3Z
07-30-2015 06:17 PM
Suburban2500
07-19-2015 04:50 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Cam upgrade questions.....
