Can Someone Clarify Tire Pressure Sensors?
I got some useful information from a search I did, but I still have some "noob" questions about the whole deal.
I know this doesn't work...correct?:
Whats this?
So the sensors are actually little small screws that are in the valve stems?
When I bought my truck it didnt have factory wheels on it AND my Low Tire Pressure code is thrown ( annoying ). So if I just ordered new wheels,tires, and sensors Ill be on the road to getting the code back off?
I also see that people are just taking them to there local GM dealership to get the codes off once everything is installed?
Sorry for all the questions, but the search only came back with like 4 threads when I used the keyword " Tire pressure sensor " lol
you can reset the check tire pressure light by letting air out of each tire individually until you hear a beep. then refill to proper air pressure
tire sensor tool
the sensors are plastic and fasten to the bottom of the valve stem, they're about 2"x1". the chevys have a mostly normal looking rubber valve stem with a brass inner section that the sensor attaches to with a small fine thread machine screw...the sensor is the expensive part, the other part is simply the special valve stem that the sensor can attach to which should be cheap. the letting air out trick works on the older GM vehicles that don't have position specific sensors, i don't know if it this works on the newer ones that have programmed positions for each sensor. the shop i work at uses a TPMS tool which communicates with each sensor and programs it to its location and to the vehicle the tires are on. hope this helps some.
EDIT: ^62nalide, yes the sensors often do come with the stem but i have seen them sold separately...
all you need is to have sensors in the wheels. if you have them in the wheels all you need is to read the owner's manual, there is all instructions you need. The reset procedure to be used after a tire rotation is the only thing you need to do to learn new/ repositioned sensors. You do a sequence inside the truck to enter programming mode then start letting air out as directed. When done refill tires to proper pressure and you are done.
High on diesel fumes
