Can Someone Clarify Tire Pressure Sensors?
Old 02-09-2012, 06:50 PM
High on diesel fumes
thunder550's Avatar
I just read the truck manual and it doesn't mention the deflate method. The G8 manual does, so maybe it depends on the vehicle? I dunno.
Old 02-09-2012, 07:16 PM
NKPPhil's Avatar
Here's what it says in my 2011 Silverado Owners Manual:
TPMS Sensor Matching Process
Each TPMS sensor has a unique identification code. Any time you rotate your vehicle's tires or replace one or more of the TPMS sensors, the identification codes will need to be matched to the new tire/wheel position. The sensors are matched to the tire/wheel positions in the following order: driver side front tire, passenger side front tire, passenger side rear tire, and driver side rear tire using a TPMS diagnostic tool. See your dealer for service.
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire's air pressure. If increasing the tire's air pressure, do not exceed the maximum inflation pressure indicated on the tire's sidewall.
To decrease air-pressure out of a tire you can use the pointed end of the valve cap, a pencil-style air pressure gage, or a key. You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match
the first tire and wheel, or more than five minutes to match all four tire
and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the engine off.
3. Press the Remote Keyless Entry (RKE) transmitter's LOCK and UNLOCK buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
If your vehicle does not have RKE, press the Driver Information Center (DIC) vehicle information button until the PRESS V TO RELEARN TIRE POSITIONS message displays. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
If your vehicle does not have RKE or DIC buttons, press the trip odometer reset stem located on the instrument panel cluster until the PRESS V TO RELEARN TIRE POSITIONS message displays. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
4. Start with the driver side front tire.
5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and that the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
9. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
11. Put the valve caps back on the valve stems.
12. Have a couple beers. (OK, I added this one myself.)
Old 02-09-2012, 07:30 PM
62nalide's Avatar
^^^^^ thank you NKPPhi you tha man!!!!
Old 02-09-2012, 08:06 PM
NKPPhil's Avatar
It's nice to be able to pay back some of the guys on this forum who have given me a ton of info. So, you're welcome!
Old 02-09-2012, 08:07 PM
Daniels2386's Avatar
Thanks for the post. Ill try this. Your truck being 4yrs newer than mine has no bearing on the procedure? I would read my manual, but Im not at home
Old 02-09-2012, 09:21 PM
NKPPhil's Avatar
I don't know what the difference might be from '07 to '11, except that I just found '06 and '08 Silverado manuals at the following url, and neither one had the procedure in it. The site doesn't have a '07 manual - go figure.
www.extendedgmwarranty.com/owners-manua/chevrolet_owner_manuals.html
Good luck!
Oobray
06-13-2022 03:38 AM
thunder550
10-08-2015 04:53 PM
Verz
08-21-2015 06:40 PM
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: Can Someone Clarify Tire Pressure Sensors?
